Hi to all,
I'm installing zabbix 1.8.3 on a VM with redhat 5, with lampp as my server, php, MySQL, etc............
As such as used this line as my configure command :
# ./configure --enable-server --enable-agent --with-mysql=/opt/lampp/bin/mysql
--with-net-snmp
The command works fine, and I start the make command :
# make install
And i get this error message :
make[3]: entrant dans le répertoire « /product/zabbix-1.8.3/src/libs/zbxdb »
gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -MT db.o -MD -MP -MF .deps/db.Tpo -c -o db.o db.c
db.c: In function âzbx_db_connectâ:
db.c:139: erreur: âCLIENT_MULTI_STATEMENTSâ undeclared (first use in this function)
db.c:139: erreur: (Each undeclared identifier is reported only once
db.c:139: erreur: for each function it appears in.)
make[3]: *** [db.o] Erreur 1
make[3]: quittant le répertoire « /product/zabbix-1.8.3/src/libs/zbxdb »
make[2]: *** [install-recursive] Erreur 1
make[2]: quittant le répertoire « /product/zabbix-1.8.3/src/libs »
make[1]: *** [install-recursive] Erreur 1
make[1]: quittant le répertoire « /product/zabbix-1.8.3/src »
make: *** [install-recursive] Erreur 1
I've been pulling my hair out over this for the better part of my afternoon........
Help !!!!!!!!!
Thanks to all in advance
--with-net-snmp
# make install
Help !!!!!!!!!
