dynamic recipient for action operations
  • xaeth
    • Nov 2004
    • 67
    Hi all. We are in the process of moving a handful of our custom notification scripts into zabbix. We effectively provide centralized monitoring of systems for a few hundred different groups.
    For the most part this should be fairly easy, especially since I think we can use a generic alert for most of the scripts. But it occurred to me today that the only way to setup the Actions to e-mail each of the groups when one of their systems is down, is to create at least 1 alert per group. This means we will have to configure lots of alerts, that are identical in content and trigger functions, but with different actions. I can imagine that being cumbersome for both using the GUI, and for maintenance going forward.
    Does anyone have any suggestion for how to handle that circumstance?
  • marcel
    • Oct 2010
    • 112
    Maybe to use Application name as an action condition.
    Zabbix Certified Specialist for Large Environments since 12/2010
    • xaeth
      • Nov 2004
      • 67
      ya.. i think thats one of the components I am going to need.
      What i'm looking at now is having a group per set of servers, and then having an overall group for this type of servers. That should handle the access permissions and association, and then utilizing the application to specify further down to just this type of alert.
      I'll update when i get it all working.
