monitoring custom services?
  • sherl0k
    • Oct 2010
    I'm having trouble trying to add services to monitor that zabbix doesn't support built-in. Items like smbd and tftpd-hpa I need to monitor, but I can't get them to monitor for the life of me.
    I've tried adding them as a service and by ip, but I get the same result:
    Active check [net.tcp.service[smbd]] is not supported. Disabled.
    and
    net.tcp.port[139]] error: Not supported by Zabbix Agent
    Where am I going wrong, how am I supposed to add a new service? I just want to see if the services are up or not.
  • marcel
    • Oct 2010
    • 112
    How about Simple check?
    section 19.6 of documentation
    tcp,139
    tcp_perf,139
    Zabbix Certified Specialist for Large Environments since 12/2010
    • MrKen
      • Oct 2008
      • 652
      and
      I couldn't get net.tcp.service[smbd] to work either. Even with [smbd,IPaddress,139]
      However, net.tcp.port[,139] works fine. You need to add the comma before the port number.
      I also use proc.num[smbd], which also works fine.
      MrKen
      • marcel
        • Oct 2010
        • 112
        net.tcp.service[service,ip,port] only works for ssh,ntp,ldap,smtp,ftp,http,pop,nntp,imap and tcp for service parameter.
        No smbd support there (yet).
        Marcel
