Hi, I'm using Zabbix v1.8.2 to survey a total of 9 servers. I'm using MySQL with InnoDB tables and the following InnoDB-Settings:
My Problem is that I get the MySQL-Error "InnoDB: Warning: a long semaphore wait:" almost once a day with transactions like:
Since these are all InnoDB issues I'm thinking about switching the engine to MyISAM. Has anyone else had this problem?
innodb_buffer_pool_size = 512M innodb_log_buffer_size = 4M innodb_flush_log_at_trx_commit = 2 innodb_flush_method = O_DIRECT innodb_log_file_size = 64M
------------ TRANSACTIONS ------------ Trx id counter 0 916566392 Purge done for trx's n:o < 0 916565583 undo n:o < 0 0 History list length 130 LIST OF TRANSACTIONS FOR EACH SESSION: ---TRANSACTION 0 0, not started, process no 9882, OS thread id 1165756752 MySQL thread id 884280, query id 1300624799 127.0.0.1 mailuser ---TRANSACTION 0 916377346, not started, process no 9882, OS thread id 1158568272 MySQL thread id 17, query id 1302251990 localhost zabbix ---TRANSACTION 0 916566391, ACTIVE 188 sec, process no 9882, OS thread id 1088555344 waiting in InnoDB queue mysql tables in use 1, locked 0 MySQL thread id 495, query id 1300624872 localhost zabbix Sending data select hostid,status from hosts where host='web2' and status in (0,1) and proxy_hostid=0 and hostid between 000000000000000 and 099999999999999 ---TRANSACTION 0 916566390, ACTIVE 201 sec, process no 9882, OS thread id 1159633232 waiting in InnoDB queue mysql tables in use 1, locked 0 MySQL thread id 499, query id 1300432513 localhost zabbix Sending data select druleid,iprange,name,unique_dcheckid from drules where proxy_hostid=0 and status=0 and (nextcheck<=1287974653 or nextcheck>1287974653+delay) and mod(druleid,1)=0 and druleid between 000000000000000 and 099999999999999 Trx read view will not see trx with id >= 0 916566391, sees < 0 916566333 ---TRANSACTION 0 916566389, ACTIVE 208 sec, process no 9882, OS thread id 1159366992 waiting in InnoDB queue mysql tables in use 1, locked 0 MySQL thread id 498, query id 1300326337 localhost zabbix Sending data select hostid,status from hosts where host='lb1' and status in (0,1) and proxy_hostid=0 and hostid between 000000000000000 and 099999999999999 ...
