Upgrade 1.8.2 to 1.8.3
  • kayjay
    • Jun 2010
    • 43
    I read the manual but I am still unclear as to 'exactly' what is required to upgrade from 1.8.2 to 1.8.3 - is there a simple step by step guide. Also how easy is it to do a clean install of 1.8.3 and transfer all my data from the old 1.8.2 server?
  • raph84
    • May 2010
    I also want to upgrade from 1.8.2 to 1.8.3.
    So far I have a test server running 1.8.3 with a copy of my production database (1.8.2). Everything seem to work fine...
    I want to make sure that I have nothing to change in the database schema before going further. Does anyone have knowledge on this?
    Thanks!
    • raph84
      • May 2010
      I Kayjay,
      After replying to your post I have done a quick search on this forum and I have found 2 thread that can help you...
      • kayjay
        • Jun 2010
        • 43
        Yes they do help thanks. The response "replace the web front end" is a little vague. The binaries are easy but I also read somewhere about a db script to run and some PHP mods to make.
