ping by operators request
  • dimm
    • Nov 2009
    I need opportunity to ping hosts(from some hostgroup) by operator like in menu Maps, Tools->Ping. It must be some list of hosts with context menu opportunity.
    How this can be done?
  • alixen
    • Apr 2006
    • 474
    You can define it in Administration / Scripts section.
    If ping is not defined there, here is my configuration:
    • Name : Ping
    • Command: /bin/ping -c 3 {HOST.CONN}
    • User groups: All
    • Host groups: All
    • Required host permissions: read
    You may have to adapt it for your needs.
    Once this is done, it will associated to Tools popup in maps.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • dimm
      • Nov 2009
      • Name : Ping
      • User groups: All
      • Host groups: All
      Regards,
      Alixen
      No, you dont understand me.
      I have this possibility in Maps(as all users of Zabbix)
      I need some list of hosts with _same_ context menu opportunity.
      This group of hosts formed by autodiscovery.
      • alixen
        • Apr 2006
        • 474
        Sorry, I misunderstood your question.
        The only places I know where Tools popup is available are Maps and host names in Monitoring/Triggers page.
        Probably not what you are looking for.
        regards,
        Alixen
