I've recently installed Zabbix Server and several agents on our production machines. Today I tried to install the agents on a batch of VMs that we have. These VMs are of a different configuration than the production machines and are running CentOS 5.5 (production are running CentOS 5.4).
When I get to the point I need to start zabbix_agentd it fails. In the log I find this batch of messages:
I googled and found regarding stuck semaphores and removed them using ipcrm, but next time I try and run it does the same thing.
Any idea where this could be coming from? If it's permissions, then permissions on what exactly?
Cheers,
DB
zabbix_agentd [9297]: Can not create IPC key for path '/etc/zabbix/zabbix_agentd.conf', try to create for path '.' [Permission denied] 9297:20101031:142428.035 Zabbix Agent started. Zabbix 1.8.3 (revision 13928). zabbix_agentd [9297]: Cannot create IPC key for path [/etc/zabbix/zabbix_agentd.conf] id [l] error [Permission denied] zabbix_agentd [9297]: Cannot create IPC key for agent collector zabbix_agentd [9997]: Can not create IPC key for path '/etc/zabbix/zabbix_agentd.conf', try to create for path '.' [Permission denied] 9997:20101031:142853.791 Zabbix Agent started. Zabbix 1.8.3 (revision 13928). zabbix_agentd [9997]: Cannot create IPC key for path [/etc/zabbix/zabbix_agentd.conf] id [l] error [Permission denied] zabbix_agentd [9997]: Cannot create IPC key for agent collector
Cheers,
DB
