event.acknowledge method
  • tthogho1
    • Nov 2010
    I tried to to add event-acknowlege message using Zabbix(1.8.3) API.
    I made json data below and send to zabbix from perl script.
    (eventid was got with event.get method)
    "jsonrpc":"2.0",
    "method":"event.acknowledge",
    "params":{
    "eventids":["104040"],
    "message":"update message"
    "id":2,
    "auth":"2cce308ce1d3447e012d7b5b7b850d60"
    But I got result like below and acknowlege message did not updated.
    {"jsonrpc":"2.0","result":{"eventids":[]},"id":2}
    How can I use Zabbix API event.acknowledge method ?
  • knightstalker
    • Mar 2010
    I had the same problem. It's actually class.cevent.php from the frontend that 'misteriously' mess up and don't actually acknowledge the event.
    I upgraded to version 1.8.4 and the problem was gone. You can just overwrite this file with the new version and you're all set.
