How to delete the "Discovered hosts" group?
  • insanelee
    • Sep 2010
    • 18
    The "Discovered hosts" group is indicated as "Templates(0) Hosts(0)" in the "Configuration|Host groups" tab, but I cannot delete it from the host groups.
    When I click "Delete selected groups" and "Go", it shows that Group Discovered hosts is internal and can not be deleted.
  • xs-
    • Dec 2007
    • 393
    This is correct, you cannot delete it. You can rename it however.
    • insanelee
      • Sep 2010
      • 18
      Thank you for your help
      • pawan.linux@yahoo.in
        • Aug 2014
        after rename the problem still on there auto registration machines also going on this host group
