Some startup help needed
  • sancho78rus
    • Nov 2010
    • 23
    We are trying to start using Zabbix and have some questions....
    Is there any way to monitor servers only with agent without forwarding ports to them? i mean that only agent send to Zabbix information and Zabbix dont send data to agent. In this way we dont need to fill in agent's ip adress and port.
  • alixen
    • Apr 2006
    • 474
    Yes.
    You need to set all items to "Zabbix Agent (Active)" mode.
    You have to make sure that Server and Hostname are correctly set in agent configuration.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • sancho78rus
      • Nov 2010
      • 23
      Originally posted by alixen
      Yes.
      Regards,
      Alixen
      thanks for reply!
      i found the same solution in russian part of forum.
