Configuring IT Services
  • obstler
    • Oct 2004
    • 30
    I'm having some difficulties setting up IT Services. What I have is a host where 4 items are checked, with triggers for each of the items. Now I thought that I could setup an entry in IT Services that would show me one status of that host, depending on all 4 items/triggers of that host.
    But when I add a new entry in IT Services, I can select one trigger in the service dialog, and below it there is a "Link to" dialog, where I thought I could add links to more triggers. But all that shows in the drop down box is the exact same trigger as selected above, and only that one.
    Maybe I'm misunderstanding how IT Services are supposed to work, but how can I get it to work as described above (so that it shows status depending on a number of triggers)?
    regards, tom.
