Problem using --with-oracle-... and --with-ldap together
  • Theoupneustos
    • Dec 2008
    I have installed and used Zabbix in the past, but this is my first time attempting to use it with an Oracle database. My DBA provided me with the Oracle 11.2 Instant Client libraries and headers, and I've run into a problem compiling.
    When I compile using --with-mysql --with-ldap --enable-server --enable-agent, the program compiles successfully. When I compile using --with-oracle-lib=/usr/lib/oracle/11.2/client64/lib --with-oracle-include=/usr/include/oracle/11.2/client64 --enable-server --enable-agent, it will compile successfully (haven't tested it yet). When I compile using the oracle options and --with-ldap together, I receive the following compile-time error:
    gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -I/usr/include/oracle/11.2/client64 -I/usr/include/rpm -I/usr/local/include -I/usr/include/gdbm -I/usr/lib64/perl5/5.8.8/x86_64-linux-thread-multi/CORE -I. -I/usr/include/net-snmp -I/usr/include -I/usr/include -I/usr/include -MT md5.o -MD -MP -MF .deps/md5.Tpo -c -o md5.o md5.c
    In file included from ../../../include/sysinc.h:321,
    from ../../../include/common.h:23,
    from md5.c:54:
    /usr/include/lber.h:204: error: redefinition of ‘struct berval’
    make[3]: *** [md5.o] Error 1
    make[3]: Leaving directory `/usr/share/zabbix/src/zabbix-1.8.3/src/libs/zbxcrypto'
    Am I missing something obvious?
    Thanks.
  • Theoupneustos
    • Dec 2008
    (bump)
    Anyone?
    • untergeek
      • Jun 2009
      • 512
      We use Oracle but don't use LDAP authentication, so I haven't seen this error
      Wish I could help more.
      • zabbix_zen
        • Jul 2009
        • 426
        ALso experiencing this on 1.8.7rc1 over Oracle 11G with the --with-ldap flag.
        Opened a bug
        here
        • vlturner
          • Aug 2011
          • 28
          See where the redefinition occurs
          See where the redefinition occurs, then look to see if the structures are identical. If they are the same but just a redefinition we can see what can be done to drop one of the includes. If they are different, then we may need to se if one is an upgrade of the other and it includes the earlier structure. If they are way too different, then we need to rethink this. And seek advisement from the lead developers.
          • Tractorboy
            • Oct 2010
            • 98
            Oracle10g with ldap
            We have zabbix with Oracle10G and ldap on red Hat and no issues at all occurred.
            We did do the original install without ldap and then added ldap after, if that makes any difference.
            • zabbix_zen
              • Jul 2009
              • 426
              Tractorboy,
              you still have to recompile the source for adding ldap later,
              that was my case.
              The difference from your scenario to mine is probably me specifically using 11G libraries,
              --with-oracle-include=/usr/include/oracle/11.2/client64 --with-oracle-lib=/usr/lib/oracle/11.2/client64/lib
              • pedrums
                • Jun 2012
                is there an ldap.h under $ORACLE_HOME?
                i has the same problem, and i made this:
                #mv /orasys/oracle/product/11.2.0.3IC/sdk/include/ldap.h /orasys/oracle/product/11.2.0.3IC/sdk/include/ldap.h.ori
                and it works
