Whats wrong with this PerfMon?
  • bytesize
    • Aug 2005
    • 71
    I'm constantly getting this error when creating a PerfMon entry:
    Parameter [PerfCounter[Processor0Time]] is not supported by agent on host [NewHost] Old status [0]
    This is my entry on the Windows agent:
    PerfCounter = Processor0Time,"\Processor(0)\% Processor Time",5
    ...and this is what I have configured as the key in Zabbix:
    Can anyone help me out?
    Thanks!
    John
  • bytesize
    • Aug 2005
    • 71
    Never mind, I've got it working now..!
    • cameronsto
      • Oct 2005
      • 148
      What'd you have to change to get it to work in case others have similar issues.
      -cameron
      • bytesize
        • Aug 2005
        • 71
        To get this to work, you need to paste this into your zabbix_agent.conf file on the Windows server:
        # Extended Processor Performance
        PerfCounter = Processor[Time],"\Processor(_Total)\% Processor Time",30
        PerfCounter = Processor[Queue],"\System\Processor Queue Length",30
        PerfCounter = Processor[0Time],"\Processor(0)\% Processor Time",30
        PerfCounter = Processor[0DPCTime],"\Processor(0)\% DPC Time",30
        PerfCounter = Processor[1Time],"\Processor(1)\% Processor Time",30
        PerfCounter = Processor[2DPCTime],"\Processor(1)\% DPC Time",30
        ...and then define the following for each entry in the Zabbix web interface:
        Processor[Time]
        ...this will enable logging of both processor if you have two installed, otherwise it will only display statistics for a single processor. This is useful for creating a standard template which you can deploy to all servers.
        Hope this helps!
