Hi everyone,
I know that this has been discussed many times here, however have an extremely strong belief that someone has at least tried to accomplished this successfully.
Is there a way to create a trigger which will fire up when an item becomes unsupoprted? The huge issue is, that ASAP the item becomes unsupported, ALL of the triggers including .nodata() gets unsupported so it is not accounted and evaluated by actions.
There is a short patch available to fix this behavior, however it is not integrated in frontend, which is a huge drawback for our operations dept.
Thanks FOR any hints - if this can be solved shomehow wit external scripts just give me a lead and I will do my very best to produce generally available script to use, however I need at least some kind of lead!
Ta,
Marcel
Ta,
Marcel
