override triggers of template_linux for a given host group
  • jmw
    • Nov 2010
    • 14
    hi,
    I use the standard zabbix template_linux for monitoring disk usage and so on...
    In the template_linux the trigger for free diskspace in /home is 10%.
    Now i've a special host group called "seeders" the /home of this host, trigger should be 2% of free diskspace.
    How can i change this for the host group "seeders"?
    ( I don't want to change every host by hand. Especially not future hosts. )
    best regards,
    JMW
  • richlv
    • Oct 2005
    • 3112
    you can override things using user macros - but either on template, or host level (not hostgroup)
    • jmw
      • Nov 2010
      • 14
      is there somewhere a documentation, that shows me, how i can use macros to define different limits for the trigger on "free diskspace in /home" ?
      • richlv
        • Oct 2005
        • 3112
        http://www.zabbix.com/documentation/...os#user_macros
