Find string into an SNMP trap
  • oct
    • Dec 2009
    • 22
    I have Zabbix 1.8.3 configured to receive traps using SNMPTT. All traps are mapped to the right host.
    I want to generate a Trigger action if no message from the backup software (Symantec's Backup Exec System Recovery) is received for the las 24 hours. I have two options:
    1. Generate a trigger using a combination of expressions to find string "besrNotification" and see if last message is older than 24 hours
    2. Create a calculated item to capture only the traps that contain "besrNotification" string on the payload and apply triggers to it.
    Can anyone help me with this?
    oct
  • oct
    • Dec 2009
    • 22
    I found a solution. I think I posted too early...
    I created a new zabbix trapper item with key snmptrapsbesr and configured snmptt.conf.BESR to redirect traps to that key instead of the generic snmptraps. This way I have an item that only receives BESR notifications. All other traps are hold by the default snmp traps item.
    Oct
