CPU Busy Percentage on the PIX-506E
  • jimbrewski
    • Sep 2010
    • 16
    On the template for the Cisco routers, there is a handy little item called CPU Busy Percentage. Does anyone know the equivalent of that for the PIX-506E? I have tried several iterations of formulas to get a report but can't seem to get any data to report. Also, if I switch to SNMPv1 Agent it tells me it's not supported -- no matter what I put in the key field. Perhaps it simply isn't supported/accessible on a PIX-506E. Thank You.
