Template_Dell_OpenManage
  • fonefone
    • Jul 2010
    • 12
    Hi All,
    I found Template_Dell_OpenManage in 1.8.3, default using "SNMPv1 agent", but can't got data,show error "error: Timeout while connecting to [192.168.0.120:161]" in zabbix log. when change type to "IPMI agent", it does not work too, no log.
    I hace enabled IPMI on the server, it can get data by using "/usr/bin/ipmitool -H 192.168.0.120 -U root -P calvin -I lan -L USER sdr"
    What should i do make the host IPMI bright?
  • PieterB
    • Jul 2010
    • 25
    Originally posted by fonefone
    Hi All,
    You have to install the OpenManage tools from Dell.
    For us it's working...
    • fonefone
      • Jul 2010
      • 12
      where i can download OpenManage tools ?
      Is it the same with idrac?
      • iaingblack
        • Dec 2010
        • 13
        Go to google and type in dell drivers support or something similar. You should get a page asking for your machines service tag. Enter it and hit ok. You should get a page where you can download all drivers and software for your machine. Failing that, find the DVDs that came with it if possible! I'm sure I could sort you out with a copy if you can figure out which version the server is expecting.
