Calculation item's formula limitation
  • SpiderX
    • Apr 2010
    • 22
    Are there any limitations in calculated items? Amount of symbols in formula field for example.
    I have an item System.Pps.Unicast. It is calculated from 28 items, everything is fine with it.
    Also i have an item System.Pps.NonUnicast. It is calculated from 28 items too, when i enable it, I'll get an error.
    In both cases all items are fully supported (example). All items have a data.
    When i remove "last("RFC1213_MIB__ifOutNUcastPkts.28")+last("RFC1 213_MIB__ifInNUcastPkts.28")+last("RFC1213_MIB__if OutNUcastPkts.27")+last("RFC1213_MIB__ifInNUcastPk ts.27")+" from formula in item System.Pps.NonUnicast, item becomes supported.
