Zabbix & Samba
  • Honey
    • Jan 2006
    Zabbix & Samba
    How can I add monitoring at the service level, say I want to monitor a Samba server, what parameters need to be set.
    Thanks,
    Honey
  • cameronsto
    • Oct 2005
    • 148
    What specifically are you wanting to monitor?
    -cameron
    • Honey
      • Jan 2006
      I would like to monitor whether Samba service is up.
      Thanks,
      Honey
      • cameronsto
        • Oct 2005
        • 148
        You could use the proc.num item to determine the number of smb processes running. See here, http://www.zabbix.com/manual/v1.1/config_items.php
        -cameron
        • edeus
          • Aug 2005
          • 120
          I would suggest using `smbstatus` or smbtree on the server as a user parameter. Then either parse through a script to get a 1 or 0 value or whatever floats your boat.
          Personally, presence of smbd/nmbd isnt a guarantee. At the end of the day, the best way is to have a script to: mount > copy a file > umount. But that is if your pedantic.
          • jsosic
            • Apr 2008
            • 47
            I monitor smbd, nmbd and winbindd processes number and memory sum with graphs. I could provide XML template if anyone is interested.
            I'm also thinking about getting number of users from /etc/passwd and if it is equal to the number of users from 'getent passwd' then winbind is not working correctly - but this is OK only for Samba servers connected to Active Directory.
            More ideas are welcome.
            • jsosic
              • Apr 2008
              • 47
              Ok, here's the template for anyone who asked
              • NigelHorne
                NigelHorne commented
                Has this been updated? That template gives this error on import:
                Invalid tag "/zabbix_export/templates/template(1)/items/item(1)": the tag "snmpv3_contextname" is missing.
