I've been successfully using the SNMP dynamic indexes on several items but recently seem to have hit a roadblock.
I've got an index which is indexed by integers:
but when I try to use it with the dynamic SNMP index Zabbix reports that it can't find the OID:
although when running snmpwalk I can see the item:
Is there any kind of workaround to be able to search for integers as well as strings in the index tables?
... CPQHLTH-MIB::cpqHeTemperatureLocale.1.1 = INTEGER: ambient(11) CPQHLTH-MIB::cpqHeTemperatureLocale.1.2 = INTEGER: cpu(6) CPQHLTH-MIB::cpqHeTemperatureLocale.1.3 = INTEGER: cpu(6) CPQHLTH-MIB::cpqHeTemperatureLocale.1.4 = INTEGER: memory(7) CPQHLTH-MIB::cpqHeTemperatureLocale.1.5 = INTEGER: memory(7) ...
Item [server1:hp.temp.max[storage]] error: Cannot find index [1.3.6.1.4.1.232.6.2.6.8.1.3.1] of the OID [.1.3.6.1.4.1.232.6.2.6.8.1.5.1["index","1.3.6.1.4.1.232.6.2.6.8.1.3.1",8]]: NOT FOUND: 1.3.6.1.4.1.232.6.2.6.8.1.3.1[8]
[marcus@monitor ~]$ snmpwalk -v 2c -c XXX server1 1.3.6.1.4.1.232.6.2.6.8.1.3.1 | grep 8\$ SNMPv2-SMI::enterprises.232.6.2.6.8.1.3.1.27 = INTEGER: 8 [marcus@monitor ~]$
