I'm new to Zabbix and I have a strange situation.
I tested a few servers to be discovered. This worked just fine. The actions defined added the hosts to the template and host group.
Next step was to add a larger IP range. The strange thing is that Zabbix find that there is a Zabbix client running on the machine but the servers doesn't get attached to the hostgroup of template.
I double checked everything and also some other topics on this forum. No solution found.
What I see if I go to Monitoring - Discovery is that Zabbix found the hostnames of servers of the first test but not from the second batch of servers. Strange. I can resolve the IP's on the command line of the server. I also added a extra action when a server is discovered to send the admin a e-mail but nothing. Nothing in the logs. Added more discovery services. No luck.
Some specs:
Running on RedHat Server 5.5
SELinux is off (Found some issue's with that if SELinux is on. Will look at that later)
Zabbix version was 1.8.3. Updated it today to 1.8.4 to see if problem resolved. No luck.
I'm dazzled and confused but trying to continue. Don't know where to look anymore. Does anyone have an idea?
Some specs:
