Upgrading from 1.1alpha2 to 1.1beta
  • rootlinux
    • Dec 2004
    • 32
    I am running 1.1alpha2 for number of months...it is working great for my compnay.
    Now, I would like to upgrade it to 1.1beta5, how can i do so?
    Regards,
    rootlinux
  • Nate Bell
    • Feb 2005
    • 141
    You need to download 1.1Beta5 and do the following:
    • Make the new Zabbix server and agents and replace the old ones (don't forget your UserParameters)
    • Replace the old web interface with the new one
    • Upgrade the database using the patches supplied in misc/ in the Zabbix install
    Nate
    • rootlinux
      • Dec 2004
      • 32
      Will test it out. Thanks,
