The Key To Sending Traps/Scripts info to Specific hosts
  • low10sws6
    • Oct 2008
    • 44
    Comments?
    i know this works very well with scripts
    //scripts ($script.sh 0.0.0.0)
    address=$1
    //traps
    read address
    address=`echo $address|cut -f2 -d' '`
    //adding this line should split up the Traps/scripts to different hosts
    gethostname=$(mysql -Dzabbix -uzabbix -pzabbix -e"Select host from hosts where ip='$address';" | tail -n1)
    ///sender
    $ZABBIX_SENDER -z $ZABBIX_SERVER -p $ZABBIX_PORT -s $gethostname -k $KEY -o "$str"
    no matter what your information your retrieving from a script or snmp trap in most in cases we only have the IP Address
    so a quick query to the database to match IP to get Hostname
    then using the zabbix sender to send it the the proxy
    just need a generic zbx trapper item/template configured in the web interface to apply to all you hosts
    then either use another zbx item to run the external script or by via cron
