My Zabbix agent v1.8.3 doesn't log anything.
No Zabbix agent log entries
Hi, thanks for your reply.
My platform is an Ubuntu 9.04 and the log location is specified in
"LogFile=/var/log/zabbix-agent/zabbix_agentd.log"
It used to work. Also I have a remote command problem with the same agent reported on ZBX-3321978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15Comment
Permissions haven't been modified, and Zabbix agent used to log a few weeks ago.
drwxr-xr-x 2 zabbix zabbix 4096 2011-01-18 06:25 zabbix-agent
-rw-r----- 1 zabbix zabbix 0 2011-01-18 06:25 /var/log/zabbix-agent/zabbix_agentd.log978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15Comment
Check up settings of SElinux policy, if you disable SElinux this problem exists?Last edited by dima_dm; 19-01-2011, 12:02.Comment
