Hi all.
I'm trouble with manage ssh agent result.
I need to check SSH connection to an host with a specific user, password and port.
So I setup an item as a SSH Agent and password and port are given as a user macro, defined in the host profile.
So, if the host parameters match witch user, password and port, SSH Agent Last Value is "0", but if not, the agent will be disabled; in this last situation, I can't manage Last Value and, so, any triggers.
Any ideas to create a trigger that tell me when SSH Agent fails???
Thanks to all!
Thanks to all!
