some questions: ping printer, vb scripts, cpu.load ...
  • JBo
    • Jan 2011
    • 310
    #16
    Originally posted by Phil2
    29069:20110124:163933.530 Item [Springerg.:net.tcp.port[192.168.114.200,80]] error: Get value from agent failed: ZBX_TCP_READ() failed [Interrupted system call]
    Are you sure that you have disconnected only the printer ?
    It looks like Zabbix server cannot join Windows server.
    Hope this helps
    JBo
    • Phil2
      • Jan 2011
      • 16
      #17
      i just disconnect the printer not the windows server, also zabbix says all is ok with the windows server.
      • JBo
        • Jan 2011
        • 310
        #18
        The message you quoted "Get value from agent failed: ZBX_TCP_READ() failed [Interrupted system call]" show that there was a problem between zabbix server and zabbix agent.
        Did you collect any value for this item before disconnecting the printer ?
        JBo
        • Phil2
          • Jan 2011
          • 16
          #19
          If i connect the printer the error message is gone.
          Where i can take a look if collect any value?
          Here my settings (item and trigger), maybe you can tell me what is wrong:
          Image hosting and photo storage for your high-res photos. Upload, organize into albums and share anywhere with ImageShack. Plans from $3.99/month.
          • JBo
            • Jan 2011
            • 310
            #20
            In Monitoring -> Latest Data
            http://img502.imageshack.us/f/zabbix2.jpg/
            That looks correct.
            Is Springer. the name of your Windows host ?
            • Phil2
              • Jan 2011
              • 16
              #21
              Yes "Springer" is the name of the windows host.
              here the monitoring data:
              • JBo
                • Jan 2011
                • 310
                #22
                Well, everything seems OK in your Zabbix setup.
                I have no idea on what is wrong.
                The only thing I can tell is that disconnecting the printer should not generate a network communication error between zabbix server and zabbix client on Windows server.
                The only explanation is that Windows server was disconnected but you already told that this is not the case.
                I hope somebody else reading this thread will find another idea.
                Sorry,
                JBo
                • Phil2
                  • Jan 2011
                  • 16
                  #23
                  Thats very strange, thanks for your help!
                  In few days i will try the same settings with a router or a pc in the network with the windows server.
                  • Phil2
                    • Jan 2011
                    • 16
                    #24
                    Hi guys,
                    I solved the problem!
                    The problem was the timeout setting on the zabbix server!
                    I put it higher and now it works fine.
                    Thanks for your help!
                    Best regards,
                    Phil
