Monitoring of zabbix proxy queue
  • konstaner
    • Sep 2010
    • 18
    Hi!
    Are there any ability to monitor queue on zabbix proxy?
    Maybe some internal item? Like zabbix[queue].
  • richlv
    • Oct 2005
    • 3112
    not really - search jira for existing feature requests, if none found, add it as a new one please
    • angelhc
      • Nov 2009
      • 226
      As I see on the "create item--> zabbix_internal type" there's one called zabbix[queue] to check the queue...
      Is it what you want?
      Number of hosts 1600,Number of items +90k,Number of triggers +22k, Number of users +100, New values per second +1270
      http://zabbixes.wordpress.com/
      • goly
        • Jan 2011
        Right - i am using the same, created additional template linked with Zabbix server. In my case these are "Zabbix queue" item details:
        Description: Zabbix queue
        Type: Zabbix internal
        Key: zabbix[queue]
        Type of information: Numeric (unsigned)
        Data type: Decimal
        Update interval (in sec) : 60
        Works perfectly
        KG
        • bashman
          • Dec 2009
          • 432
          Voted!
          978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
