SSH Ports
  • Lozzano
    • Jan 2011
    • 12
    SSH Ports
    I am having some issues as a newcommer to Zabbix, and hope to get some help here.
    What I'm looking for, is to change the port ssh checks on, as I changed it. I have tried browsing this forum, and it says I should change it to net.tcp.service[ssh,,PORT] but it just goes on 'Not Supported' after a while. Does anyone know how to fix this?
    Thanks a lot in advance!
  • JBo
    • Jan 2011
    • 310
    According to documentation, proper syntax is net.tcp.service[service,<ip>,<port>] so you should use net.tcp.service[ssh,,PORT].
    Arguments between <> are optional.You can leave <ip> empty but make sure that you have 2 comas between "ssh" and port number.
    Hope this helps;
    JBo
    • Lozzano
      • Jan 2011
      • 12
      Thanks works!
