Can Zabbix dynamically change severity level for Nagios
  • honglus
    • Jan 2011
    In Nagios, returned value 1 =WARNING, 2=CRITICAL.
    How can zabbix interpret the value and dynamically set severity level accordingly without creating two triggers?
    Zenoss can sort of support this via next highest severity.
    Does Zenoss use severity set by the Nagios Plugin return?
    Yes. Per Chet Luther:
    You can use the 1/2 exit codes from Nagios plugins to drive the severity of the resulting Zenoss event.
    The way it works it that if the plugin exits with a code of 1 (WARNING) Zenoss will set the severity of the event to whatever you selected for severity when you created the data source. If the plugin exits with a code of 2 (CRITICAL) Zenoss will use the next highest severity. An exit code of 3 (unknown) will give the same severity as the data source.
    So if you choose Warning as the severity in the data source, and the plugin exits with a code of 2, the event will actually have a severity of Error.
  • zabbix_zen
    • Jul 2009
    • 426
    Hi.
    I'm feeding Zabbix with a bunch of Nagios both
    via HTTP accessing http://remote_IP/nagios/cgi-bin/tac.cgi
    and
    grabbing current_state and service_description from other nagios /var/log/nagios/status.dat
    Errr... currently you cannot.
    I agree this is useful for a variety of cases.
    I've opened a Request
