log monitoring: alerts from very old values
  • grenzlaeufer
    • Nov 2010
    • 24
    Hallo!
    I have achieved to monitor failed login attempts on our servers with zabbix, but i have a serious problem: I regularly get alerts from old login attempts which are up to 3 months old! I hoped old alerts would vanish with the time, but even after a month I get several old values/alerts a day.
    I am using Zabbix 1.8.3.
    Item: Configuration:
    Type: Zabbix agent (active)
    Key: log[/var/log/messages,"Authentication failure"]
    Update: interval: 10 sec
    Status: active
    Has anyone else experienced this problem?
  • angelhc
    • Nov 2009
    • 226
    As I can see on your item configuration:
    log[/var/log/messages,"Authentication failure"] you're looking any "Authentication failure" on any line.
    Try og[/var/log/messages,"Authentication failure",30] to search only the last 30 lines.
    Hope this help
    Number of hosts 1600,Number of items +90k,Number of triggers +22k, Number of users +100, New values per second +1270
    http://zabbixes.wordpress.com/
    • grenzlaeufer
      • Nov 2010
      • 24
      Thank for the reply angelhc!
      I´ve just configured it. If you don´t heare anything from me, than it works.
