Snmp community macro
  • szenrobi
    • Jan 2011
    • 13
    Hi !
    I would like to use a macro to change snmp community.
    But I have problems.
    First I wanted to make a simple check, if it would work.
    I made a new item with setting the macro value: {$CONSTRING} -> public
    After I entered the same host item menu, created an snmpv1 query, and at the SNMP community field i wrote: {$CONSTRING} .
    But unfortunatelly in the zabbix log i saw timeout, the values did not update.
    The equipment is a switch, i can ping, and snmpwalk is working.
    What is the problem ?
    Robert
