Exporting web scenarios?
  • ctang
    • Jan 2011
    I created a bunch of web scenarios on a Zabbix server, and I would like to copy them to another Zabbix server instance. Does Zabbix support export/import of web scenarios (like it does for templates and hosts)? I haven't been able to find it.
    Thanks,
    Calvin
  • girishkg
    • Aug 2011
    • 11
    Re: Exporting web scenarios?
    This could be an useful add on if added to zabbix. But it seems currently zabbix doesn't have this functionality; even it doesn't include "Web scenarios" in "Host Export". So, hard time for us really.
    • emmanux
      • Mar 2013
      • 47
      It is doable by API:
      Scripting it would be matter of some hours (minutes?) of intense creative energy. May the Force be with you.
      I think ZABBIX SIA is planning to release that feature in the near future.
      • emmanux
        • Mar 2013
        • 47
        Or, you can use my script. It creates templates in the new Zabbix Server, with the names of the hosts in the old one as hint. You need to apply those templates to the actual hosts in the new environment.
        https://gitlab.com/emmanux/zabbix-to...eb-migrator.pl
