i would like to send email-notification from zabbix to Spiceworks..
in Spiceworks it gives an example for nagios.. but how is it for zabbix? can somebody help me?
# This is the built-in example external alert email parser. It supports parsing emails from
# the Nagios system, but could also be changed to parse email from other systems.
# three variables are passed into this function:
# - email_from: the sender, email_subject: the subject, and email_body: the email text
data = nil
# comment out if you want to create alert for a reply that contains nagios alert text instead of creating a ticket
return nil if email_subject =~ /^Re:/i
# Tweak regex to match string present in Nagios alert email.
if email_body =~ /\*{5}\s+Nagios\s.*\*{5}/
# this email is sent from Nagios, parse alert tokens
data = {}
data[:notif_type] = email_body[/^Notification Type:\s*(\w+)/, 1]
data[:hostname] = email_body[/^Host:\s*(.*)/, 1]
data[:ip] = email_body[/^Address:\s*(.*)/, 1]
data[:alerttype] = email_body[/^State:\s*(.*)/, 1]
data[:title] = (email_body[/^Service:\s*(.*)/, 1] || "Host #{data[:hostname]} is #{data[:alerttype].to_s.downcase}") + "#{' at ' + site_name if site_name}"
data[:created_at] = email_body[/^Date\/Time: *(.*)/, 1]
data[:message] = email_body[/^Info:\s*(.*)/, 1]
data[:ainfo] = email_body[/^Additional Info:\s*\n+(.*)/m, 1]
data.each_key{|k| data[k].strip! if data[k]}
end
return data # an external alert is created with returned key/value pairs
