I've configured a couple IP Range (e.g. 10.10.129.1-255) discoveries and the check I specified is "Zabbix agent". The discoveries are active.
I have two Linux hosts on that subnet that are running the Zabbix agent. In fact I can see that the zabbix server sees them...
If I manually create the host "rails" on the Zabbix server, it will start checking that system. Why isn't it finding it in the discovery process and listing it there first?
Matt
3963:20110129:173235.589 Sending list of active checks to [10.10.129.30] failed: host [rails] not found
Matt
