Problem using last function in calculated item
  • Zapper
    • Apr 2010
    • 11
    Hi All,
    I have an item key which work fine. But when i try to use it as calculated item and i use the formula below it says "not supported". Is there anything wrong with the formula.
    last("myStuff["java-query:name=queryCounterBean,type=QueryCounterResou rce,attribute=queryCounter","{$My_PORT}"]")/30
    I do have a trigger for this which also works fine.
    Tailing server logs:
    error: Can not evaluate function [last(type=QueryCounterResource,attribute=queryCoun ter"])]: item [hostname:jmx["java-query:name=queryCounterBean] not found
  • nelsonab
    • Sep 2006
    • 1233
    You might need to escape some of your quotes, or get rid of some, as it's hard to figure out what's nested and what's not right now
    try this:
    last(myStuff["java-query:name=queryCounterBean,type=QueryCounterResou rce,attribute=queryCounter","{$My_PORT}"])/30
    RHCE, author of zbxapi
    • Zapper
      • Apr 2010
      • 11
      Thanks nelsonab for your reply. Now i am getting "error: Invalid first parameter in function"on the server log
      • Zapper
        • Apr 2010
        • 11
        It works fine now. Had to use \ in front of all the double quotes
