I am trying to generate a Map for about 50 remote Sites with only one Host in it.
I made a "sample Map" that i exported to XML to be able to generate the 50 other maps.
My problem is about the selementid tag wich seems to be auto incremented by zabbix at the map creation.
I could of course increment myself this number in each generated maps or choose a high number wich will certainly never be used by zabbix but i am not sure what might be the proper solution to not interfere with zabbix's way of working.
Thanks by advance of any help.
Cheers,
Cheers,
