Cpu load
  • iamyuweiii
    • Feb 2011
    • 12
    Cpu load
    Hi I am new to zabbix, i tried to monitor the my windows cpu load using zabbix. i tried to create an item in the web interface but after i create the item. the status state there not supported.. may i know the reason and solution to it?
  • JBo
    • Jan 2011
    • 310
    Maybe you could describe in more detail what you have done.
    How have you defined your item ?
    Regards,
    JBo
    • iamyuweiii
      • Feb 2011
      • 12
      CPU Load
      i went to zabbix web interface and create an item in it. i follow the steps in the zabbix manual but at the status column its stated not supported by zabbix agent. Thanks
      • nelsonab
        • Sep 2006
        • 1233
        Perhaps you can post either a screenshot of the item configuration or tell us what key you used?
        RHCE, author of zbxapi
        • iamyuweiii
          • Feb 2011
          • 12
          CPU Load
          Hi I have already attach the file below.
Name:	CPU Load Status.jpg
          • nelsonab
            • Sep 2006
            • 1233
            <1 is not a valid cpu identifier. you can also leave that field blank unless you are interested in the load of a specific processor.
            • iamyuweiii
              • Feb 2011
              • 12
              CPU Load
              Hi Nelsonab, it is still not supported even if i leave it blank.
