AIX configuration
  • tommy13v
    • Jan 2005
    AIX configuration
    Anyone using zabbix agentd with AIX? I have it installed and such but alot of the useful reporting that I want like network in and out is "not supported". Also disk reads and writes.
    Can anyone point me in the right direction?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Not everything is supported under all platforms. See table of supported parameters by platform in ZABBIX Manual.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • tommy13v
      • Jan 2005
      I see that now, thanks. I guess I am stuck with using SNMP instead. Is there a possibility that these will be included at some point? We have 50 AIX servers.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Yes, I believe it will be implemented at some point. I cannot give you ETA. Alternatively you may consider funding development of discussed functionality to have it ready quickly.
        Alexei Vladishev
        My Twitter
