trigger {Standard PING:icmppingsec.max(120)}>300 does not work
  • ahuser
    • Feb 2011
    Hi @ all,
    I have to build two triggers for icmpping alerts
    1. {Standard PING:icmppingsec.max(120)}>300
    2. {Standard PING:icmppingsec.avg(#10)}=0
    but max or average or any other doesn't work correctly I become for all single peak an alert .
    Whats wrong i can't find the bug in the string
    item ist configured:
    icmppingsec
    nummeric (float)
    ms
    multiply = 1000
    interval = 1sec
    and the triggers such as top described
    thx for the anwers and sorry for my bad english
    Andreas
  • zabbix_zen
    • Jul 2009
    • 426
    Hallo Andreas.
    If I've correctly understood your problem,
    for #1 you'll want
    {Standard PING:icmppingsec.min(120)}>300
    meaning, it'll only trigger when the min value from the last collected 120 seconds is bigger than 300 (thus filtering sporadic spikes)
    For, #2
    I didn't quite understand the issue.
    It should only trigger when the average from the last 10 collected values is 0.
    you could replace it by
    {Standard PING:icmppingsec.max(#10)}=0
    • bernard
      • Oct 2008
      • 54
      use min instead of max
      Same as zabbix zen (but he writes faster than me ;-))
      Use min() inseated of max(). Doesn't make sense ?
      Explanation:
      you want to get an alert if ICMP ping sec value is over 300 during 2 minutes.
      in your trigger expression icmpingsec.max(120)}>300 means: if during last 2 minutes, the maximum value is greater than 300. You trigger will fire at the first time value is greater than 300.
      Think another way:
      use min: if during last 2 minutes, the minimum value is greater than 300, the trigger goes on. This means your values are over 300 for 2 minutes.
      Sometimes I need to write on the paper to be sure to create the correct trigger.
      1. {Standard PING:icmppingsec.min(120)}>300
      try
      2. {Standard PING:icmppingsec.max(#10)}=0
      Best Regards,
      Bernard
      • ahuser
        • Feb 2011
        Thank you very much for the answer!
        If one understands the logic is much easier
        You did great work!
        Greetings from Germany
        Andreas
