Monitoring usage of teracopy.exe
  • DonnEdwards
    • Feb 2011
    • 19
    I have the Zabbix agent installed on a Windows 2000 server. Every now and then during the day there is a scheduled task that runs a batch file that copies data using teracopy.exe
    Is there any way of getting Zabbix to record when this happens? The copying takes a long time (i.e. 30-60 minutes) so there should be plenty of time to notice that its running.
    I thought of just using the network traffic monitor, but it doesn't give me the same information, especially if teracopy stops with an error (i.e. it is still running after 2 hours but there is no network traffic).
    Any suggestions, tips, or manual section numbers, would be greatly appreciated.
    Donn
