system.cpu.util not supported by agent
  • verus
    • Feb 2009
    • 67
    I want to monitor "system.cpu.util" but i get "not supported by zabbix agent".
    The server is 1.8.4
    The agent is 1.8.4
    The monitored server is a windows server 2003, 32 bit.
    The item is:
    Type: zabbix agent
    Key: system.cpu.util[,system,avg1]
    Type of information: Numeric (unsigned)
    Data type: Decimal
    Units: (nothing)
    The log shows this:
    Item [SRVR_BE_BR_Cx_Server:system.cpu.util[<cpu> <,type> <,mode>]] error: Not supported by Zabbix Agent
    Parameter [SRVR_BE_BR_Cx_Server:system.cpu.util[<cpu> <,type> <,mode>]] is not supported, old status [0]
    How is this possible, what am i doing wrong ?
    thanks,
    Verus.
  • verus
    • Feb 2009
    • 67
    I found the solution.
    item had to be "numeric - Float".
    cheers.
    • Predatorian
      • Apr 2013
      • 12
      I keep getting this issue with running it directly on the agent. I keep getting:
      # zabbix_agentd -t system.cpu.util[]
      system.cpu.util[]                             [m|ZBX_NOTSUPPORTED]
      I haven't seen a good solution yet besides its a bug.
