How to create a trigger that checks if the PC is Frozen
  • maffapl
    • Feb 2011
    Can someone please help me as to how can I create a trigger that checks if the computer is frozen.I am not sure if {MyPC :: perf_counter[\System\File Read Bytes/sec].last(0)}=0 will work fine to determine if the computer is frozen.
    Thanx.
  • untergeek
    • Jun 2009
    • 512
    Um, usually you won't get responses from Zabbix if the computer is well and truly frozen. Create an item that is of type Zabbix Agent(Active), then trigger on that item if nodata(300)=1 (i.e., true if no data received in over 5 minutes).
    • maffapl
      • Feb 2011
      Thanx untergeek, I appretiate ur response.
