Access to screens
  • angelhc
    • Nov 2009
    • 226
    Access to screens
    Hello all,
    We need to give access to some screens to one user, but only to that screens not the whole zabbix application.
    Has someone do it?
    Thanks!!
    Number of hosts 1600,Number of items +90k,Number of triggers +22k, Number of users +100, New values per second +1270
    http://zabbixes.wordpress.com/
  • tchjts1
    • May 2008
    • 1605
    Not sure what you mean by "Whole Zabbix application". If you create an account for that user and give them read only access for the server which has the screens assigned to it, then they won't have much more access than that. But they will be able to see other areas associated with that server, such as Latest Data.
    • angelhc
      • Nov 2009
      • 226
      What we need is a user who can only view the screens tab and no more.
      Cause those users are from bussiness and they're not interested in technical data like "Latest Data".
      I think one solution could be make a .php with access to this tab....
      Thanks!
      • thiagolmelo
        • Dec 2009
        • 27
        by native mode, I dont hink that you can access only screen tab, but you can create a new php and, by API, select only screen tab to user see. :-)
        Best Regards
        __________________
        Thiago Melo
        [url]www.zabbix.com.br[/url]
        [url]www.uniredeinfo.com.br[/url]
        Porto Alegre - RS - Brasil
