Can zabbix be set up to notify me when the server is unreachable for a tenth of a second?
setting up conditions
Tags: None
let me know if the "server" means "zabbix server" or "host server"
In the case "host servers", yes, you can create a action based on a trigger to you receive this message.
In the case "zabbix server", you cannot create a monitor by zabbix to you receive a message when it is out. You can create a script and put it on cron to send a mail when Zabbx_server is out or create a node of zabbix to one node monitoring each other.
Beste Regards__________________
Thiago Melo
[url]www.zabbix.com.br[/url]
[url]www.uniredeinfo.com.br[/url]
Porto Alegre - RS - Brasil
