Websites monitoring - Sessions, navigation, recording and parametrization
  • ViF
    • Mar 2011
    Hi all,
    I'm trying to find a way to use the Zabbix Web Monitoring to control a complex web navigation.
    Is there a way replay (or to record) the complete set of http requests that simulates a complex navigation and replay all the steps mantaining the same session ID?
    Or, for example, a way to save some parameters (as session ID) and pass them trough the Http post/get of a single navigation?
    Last question: is there a tool that make possible to record the steps of a web navigation, to generate a script that makes zabbis able to simulate and replay navigation (as HP Vugen do, for example)?
    Thanks a lot!
  • marcel
    • Oct 2010
    • 112
    Use Selenium (search for Selenium IDE), run it separately and then use zabbix_sender to inform Zabbix server of the result
    Zabbix Certified Specialist for Large Environments since 12/2010
    • da_oli
      • Oct 2010
      • 34
      Hi Marcel,
      i'm really interessted in the selenium solution.
      Do you have a smal howto or best pratices?
      greets
      Oliver
      • marcel
        • Oct 2010
        • 112
        Selenium IDE in Firefox -> testcase.php
        edit testcase.php for status outpud -> 0 for OK, 1 for FAIL
        crontab -> shell wrapper -> run php testcase.php -> run zabbix_sender with output information
        I am seriously busy these days, maybe sometimes I will create a more detailed howto
        marcel
        • ViF
          • Mar 2011
          Interesting!
          Absolutely interesting....if you could provide us some other detailed info, it would be appreciated!
          I'm considering the TWILL solution too....
          • bhagwati
            • May 2014
            Intergrate Selenium with Zabbix
            Hello ,
            I want to monitor web checks in Zabbix like number of users logged in ,uploaded document can be edited etc
            I got an idea of selenium after long search .. Can anyone provide me the way to integrate selenium into zabbix
            As am new to Selenium
