Hi all,
I'm probably blind or I haven't slep enough tonight but i can't find where to reset trends data.
I just changed data unit (from B to b) in some items i use to plot the bandwidth usage and I need to reset the data (history and trends) stored till now to be able to plot a graph with correct values but I can't find where to reset the trends.
To reset the history I'm:
- going to configuration->host
- selecting the host
- slecting the items I want to reset
- at the bottom of the page i select "clear history for selected"
- press "go"
...but how am I supposed to delete trends data?
Thx
Inc0
- press "go"
Thx
Inc0
