Hi.
I'm having trouble in a new Zabbix installation over Oracle XE (10G).
From my zabbix_server.conf
The DB is up and running, zabbix schema is correctly populated and frontend successfully connects and allows for normal operation,
but as soon as I /etc/init.d/zabbix_server start
my listener gets flooded with messages similar to, (port numbers always increasing)
Why is zabbix_server spamming so many sessions/services and how to solve it?
ListenPort=10051 # zabbix host dnsname DBHost=dev-zabbix02 # DB service name as defined in $TNS_ADMIN/tnsnames.ora DBName=XE DBUser=zabbix # All DB, schema and credentials were successfully tested using sqlplus DBPassword=zabbixpasswd DBPort=1521 # host IP ListenIP=10.110.15.10
15-MAR-2011 12:16:39 * (CONNECT_DATA=(SERVICE_NAME=XE)(CID=(PROGRAM=zabbix_server)(HOST=dev-zabbix02)(USER=zabbix))) * (ADDRESS=(PROTOCOL=tcp)(HOST=10.110.15.10)([B]PORT=44634[/B])) * establish * XE * 12516 TNS-12516: TNS:listener could not find available handler with matching protocol stack 15-MAR-2011 12:16:50 * (CONNECT_DATA=(SERVICE_NAME=XE)(CID=(PROGRAM=zabbix_server)(HOST=dev-zabbix02(USER=zabbix))) * (ADDRESS=(PROTOCOL=tcp)(HOST=10.110.15.10)([B]PORT=44635[/B])) * establish * XE * 12516 TNS-12516: TNS:listener could not find available handler with matching protocol stack
