Using Last Function within Calculated Items
  • yummysmokedham
    • Mar 2011
    My end goal is to calculate input and output port ethernet port utilization on our core switches, right now I am just trying to get the last function to work correctly. I have an SNMPv1 value that is working properly with the key name of ifspeed1. I am trying to create a calculated item using this SNMPv1 value. I have tried last("BROCADE_CES_INTERFACES:ifspeed1"), last(BROCADE_CES_INTERFACES:ifspeed1), last("BROCADE_CES_INTERFACES:ifspeed1.0"), and several other different combinations. My audit log returns something similar to this each time, items.error: Can not evaluate function [last()]: item [BROCADE_CES_INTERFACES:ifspeed1.0] not found =>
    Is something wrong with my syntax?
    Thanks in advance.
  • yummysmokedham
    • Mar 2011
    my goal will be to have a formula in the end that looks something like this (I know the formatting is wrong, the formatting follows the trigger syntax)
    {{BROCADE_CES_INTERFACES:ifOutOctets1.last(0) - BROCADE_CES_INTERFACES:ifOutOctets1.last(#2)} * 8 * 100}/{90 / {BROCADE_CES_INTERFACES:ifSpeed1.last(0) * 100000}
    • stepedro83
      • May 2011
      I have the same problem, someone found a solution?
