Understanding SNMP ifInOctects graph
  • manolopm
    • Mar 2011
    Hi:
    I have a Gb net. I ask my router for ifInOctects and IfOutOctects using the SNMP v2 template that comes with debian package. All seems correct and working, as I understand the raw value are octecs so If I get 2117042927 it means 2.1 GB/s
    And thats its my question, how it's this possible? Because my network it's only 1 Gb/s (0.125 GB/s)
    Regards from Canary Islands
  • Gav
    • Jun 2010
    • 12
    ifInOctets / ifOutOctets stored values for bytes from the beginning of all time on the device.
    You need to set in intems that the value is represented as a Delta
    Store value As isDelta (speed per second)
    This will return current value for you (in bytes); I personally use custom multiplier (8) so the value is in bits
    • manolopm
      • Mar 2011
      Thanks Gav. That solves my doubt and work perfect. Thanks again
